400 draft
Forum Name: 400
URL: https://www.myhanse.com/forum_posts.asp?TID=8915
Printed Date: 28 February 2024 at 09:06
Topic: 400 draft
Posted By: Rock
Subject: 400 draft
Date Posted: 18 March 2015 at 20:38
Being lifted today, I took the opportunity to check the excact draft of my 400e with shoal keel.
Depending on the source, even from Hanse itself, I sometimes read 1.60m and sometimes 1.65m.
Turns out it is about 1.72 m, in my case.
Measured the waterline on the antifouling to the ground and  deducted hight from ground to bottom keel, on both sides and averaged.
I like that, better a little more than a litte less, benefits the pointing but still allows me to park the boat behind the house Smile.
Peter.
Hanse 400e "M-square2" #0241
Posted By: Peter-Blake
Date Posted: 19 March 2015 at 09:07
The truth is:
Mainly all  boats have a slightly bigger draft than the papers.
The papers are without the load of full water tank, full fuel tank, personal equipment and so on.
My 370 has a draft of 195cm following hanse catalog.
In truth i have 205cm.....
Blake 370
Posted By: Stella*Nova
Date Posted: 19 March 2015 at 11:06
On my H 370 I had exactly 2m instead of 1,95m. As the boat was fully loaded for a long holyday trip we had 2,05m-2,10m. It depends on the beer load.
I could imagine, if the boat is completely empty the draft should be around 1,95m as documented.
BR Ralf, Ex. 'a mare' H370
