Fuse panel
Forum Name: 345/348
URL: https://www.myhanse.com/forum_posts.asp?TID=9238
Topic: Fuse panel
Posted By: ccharlie
Subject: Fuse panel
Date Posted: 18 September 2015 at 23:29
I caused a short circuit in the cockpit lamp. The roof-lamps in the sleeping cabins and the bathroom/toilet don't work anymore either. Apparently they form a group and I hope it's only a fuse; alternatively, a driver unit may be damaged. My 2015 Hanse 345 is equipped with a DC-panel TEV0605; however, the folder is not very informative. I cannot find a faulty fuse. Would anybody have suggestions or a scheme ? Frank
------------- Simcha Hanse 345 #192
Date Posted: 19 September 2015 at 05:43
Simcha,
There are fuses on the back of the panel in your photo. They are in two layers. The fuses for Interior Lighting Groups 1 & 2 are in the second layer. They are a bit difficult to get to but they can be reached with small curved pointy nosed pliers. The two fuses are 15 amp mini blade fuses just near the top of the panel and are marked XB1.1.1-XB1.1.5 and XB1.2.1-XB1.2.5. They are the only 15 amp fuses in this area. I am not sure which is for the aft and which is for the forward lighting but the problem is likely to be one of these fuses. You can test the flush whilst in place because they have contacts on the top of them. Just put the tips of the prongs of your multi meter on the two contacts. Set the multi meter to "resistance" and it should "beep" if the fuse is OK and show zero and no beep if the fuse is blown. Turn the battery power off before testing and during the removal and replacement of the fuse.
Posted By: ccharlie
Date Posted: 20 September 2015 at 12:15
Wayne, thank you for your very helpfull reply. I am on holiday sailing in France and do not have a multimeter here. But I could test by swapping the fuses. The red light on the fuse panel is blinking and this indicates a broken fuse.
The 2 fuses you mentioned are OK: the left (aft) one is for the touch-switchboard, the right one for all the readinglamps. There is a third 15A fuse on the right side somewhere in the middle, it is also in the scheme/folder: "Innenbel. K1.2". That is the one I was looking for!
Date Posted: 20 September 2015 at 12:43
Frank,
Sent me your email address via the "PM" option on this website and I will email you some further information.
Date Posted: 20 September 2015 at 12:52
Frank,
There is a 15 amp fuse on the left (bow side) of the board which according to the drawing is for the "interior group lighting 3" so this could be the one. On the left side going from top to bottom there is a 5 amp, 10 amp, 5 amp the 15 amp and a further 15 amp. The fourth from the top - the first 15 amp could be the one causing the problem. Just aft of this fuse the next block has "Innebel K1.2" written under it on the drawing.
Posted By: SausalitoDave
Date Posted: 20 September 2015 at 12:58
I have the manual for the TEV0605, it is a 6MB .pdf, if you want a copy send me a pm with your email address and I will mail it to you. It has all the fuse locations and a wiring diag.
Dave Festina Lente Hanse 505
Posted By: Pepote
Date Posted: 20 September 2015 at 17:14
Dave, Could you please send to me the manual for the TEV0605? This is my e-mail adress: mailto:forestal@telefonica.net" rel="nofollow - forestal@telefonica.net Many thanks. Jesús
------------- Jesús
Date Posted: 21 September 2015 at 08:19
Posted By: Pepote
Date Posted: 21 September 2015 at 17:07
Hi David,
I’ve already received the
manual!
Many thanks.
------------- Jesús
Posted By: Peter-Blake
Date Posted: 21 September 2015 at 18:19
It would be nice to post the manual in the manual section, so every other Hanse owner could check for it. Thx
------------- Blake 370
Date Posted: 22 September 2015 at 01:03
Peter, I tried to do that a while ago; however, at 7.5 MB, it won't upload. Since there is no .zip file type accepted, I can't figure out another option. Happy to send it to you if you think you can figure out how to upload same.
Posted By: richz
Date Posted: 26 September 2015 at 11:56
it should be there now (if I got it right)
Posted By: Aeneas
Date Posted: 06 October 2017 at 16:02
Hello Dave,
I'm searching for the TEV0605 Panel manual with fuse locations and wiring diag.
Please mail it to me at: ubold.froentjes@gmail.com
With kind regards,
Aeneas, Holland.
Posted By: Aeneas
Date Posted: 06 October 2017 at 16:31
Hello,
I'm looking for the TEV0605 Panel manual with fuse locations and wiring diag.
Please mail it to me: ubold.froentjes@gmail.com
Greetings from Holland, Aeneas.
Posted By: richz
Date Posted: 06 October 2017 at 23:37
Try here: http://www.myhanse.com/dc-panel-tev9605_topic9249.html
Posted By: Aeneas
Date Posted: 08 October 2017 at 20:03
Hello richz,
thank you very much; this post is outstanding !!
Can you/ anyone else tell me which connectors can be used at the rear front of the TEV0605 Panel ???
There are 3way, 4 way, 8way and many 14way connections.
Please help and mail to me at : ubold.froentjes@gmail.com
Aeneas.
Date Posted: 09 October 2017 at 15:29
Hi Aeneas, you have mail with everything I have created around the Würth panle mystery. You wil also see the connectors. You can buy the blue/grey plugs from hanse.boatoon.com
BR
------------- Frank
Posted By: Aeneas
Date Posted: 09 October 2017 at 19:27
Hi BR,
where is the information with everything about the Wuerth (TEV0605) Panel ??
I need the hardware Info, not the software !!
I don't see any Information in my Email!!
Where can i see the connectors ???
Please try again: ubold.froentjes@gmail.com
Date Posted: 09 October 2017 at 20:29
Aeneas, please calm down!
Everything is in the attached .ppt. It is slightly above 7 Mb, so check your inbox again! Have sent it again 2 mins ago.
Kind Regards
------------- Frank
Posted By: Oscman
Date Posted: 18 November 2018 at 18:07
I'd like to add few electronic gadgets to my boat and connect them to control panel but I'm not sure how to connect them to spare switches. You mentioned that you have manual for TEV 0605? Any chance you could send me a copy
Regards Adam
Posted By: ccharlie
Date Posted: 18 November 2018 at 22:47
Oscman, I can email you the TEV 0605 diagram what's adress ?
Date Posted: 19 November 2018 at 03:01
Hi Oscman, you need these blue/grey plugs, which you can obtain from Boatoon.com. If you pm me your e-mail address I can send you detailed information about the mysteries of the dreaded Würth panel. This shows you where to plug in your new accessories. BR Frank
------------- Frank
Posted By: Toftager
Date Posted: 04 June 2020 at 22:34
Hi All
Any chance someone is still around, that is willing to share the file with info about the panel with me?
Thanks in advance
/Peter
Date Posted: 05 June 2020 at 03:06
Peter,
please om me with your e-mail address
BR
------------- Frank
Posted By: jurgencm
Date Posted: 03 July 2020 at 22:37
Hi Fendnt, Can you please also email the diagram for the Würth panel. Thanks Jurgen jurgencm@me.com
Posted By: RICARDO51
Date Posted: 30 September 2020 at 21:07
Hello Dave, Hope you still have that manual in PDF It is really important to have it. Can’t find the location of the fuses for each circuit. So simple and though so messy 😡 Would appreciate you sending it to my email: r2stier@gmail.com Thank you so much. Best regards, Ricardo
Date Posted: 30 September 2020 at 21:12
Hello Dave, Hope you still have that manual in PDF Would be utmost useful for me. Can’t find the location of the respective fuses for each circuit. So simple and though so messy 😡 Thanks for your help My email: r2stier@gmail.com Best regards, Ricardo
Date Posted: 30 September 2020 at 21:16
Hello Fendant, Would also appreciate you sending it to me. Thanks and best regards Ricardo r2stier@gmail.com
Date Posted: 01 October 2020 at 01:40
That works, but what I ended up doing as well is swapping them out with "glow-when-blown" fuses. I put the old ones in a bag (after checking them out) and simply swapped the 10amp for 10amp, 25 amp for 25amp, and so on. From that point on, I did not need to look at the diagram. I just swapped the one that was lit up.
FWIW
Posted By: Jackdaw
Date Posted: 01 October 2020 at 02:01
I would also like to get a copy of the manual for the panel, my email is andrei@svjackdaw.net Thanks in advance!
Date Posted: 01 October 2020 at 13:33
Jack, Ricardo,
I can send you the manual and the fuse locations tonight. Jack, please PM me your e-mail adress
BR Frank
------------- Frank
Posted By: Vind
Date Posted: 26 February 2023 at 10:49
hi, would it be possible to send it to me as well. Bojelarsen@gmail.com
Thanks in advance Anders
Posted By: FredrikHanse
Date Posted: 27 May 2023 at 10:24
Hi All
Any chance someone is still around, that is willing to share the file with info about the panel with me? My Mail: Fredrik.krafft@gmail.com Thanks in advance
/Peter
