some water (100 ml) in front section below anchor
Forum Name: 345/348
URL: https://www.myhanse.com/forum_posts.asp?TID=9622
Topic: some water (100 ml) in front section below anchor
Posted By: Armin
Subject: some water (100 ml) in front section below anchor
Date Posted: 17 May 2016 at 20:48
I have got my new Hanse 345 in April 2015. After a very wet sailing exercise last week (16 hours in 5-6 Bft half-wind) I have found some water (some 100 ml) behind the small maintenance access in the front cabin (under the anchor-chain box). Although it was only a very small volume I wonder if this could be the result of a poor sealed connection which could lead to long-term damages. Any ideas if this could be a normal water volume I have to expect? Maybe I am a bit nervous as this is my first own boat.
Thanks for your thoughts!
Armin
Posted By: gertha
Date Posted: 17 May 2016 at 22:36
Armin,
I have sailed my own hanse over 30k miles in last 10 years.
We always have water on board.
Some from windows, some from people going below wet, some from joints.
I would not be suprisd to get 20 to 30 lts of water below in a 2 day wet passage.
Your boat like my boat will not last for ever; a small amount of water is not a problem.
I have sailied a lot in the last 10 years and will probably sail a lot more in the next 10 years ; at the end if boat is scrap it is no problem.
We could spend 3 times on a Halberg or X; and have a longer lasting boat; but be worse off.
Enjoy your boat and do not worry about odd small leak.
I pumped out over 100 lts after a 7 day trip in very bad weather.
Simon
Swanned off
Posted By: Armin
Date Posted: 17 May 2016 at 22:53
Thanks Simon! Guess thats spot on the right answer!! As I said ... first ownership ... not always sure what is right and whats wrong! But sometimes clear words do help!
Armin
