Fault in RPM & Engine Hour meter
Forum Name: 311 / 312 / 315
URL: https://www.myhanse.com/forum_posts.asp?TID=9813
Topic: Fault in RPM & Engine Hour meter
Posted By: Sailbonbon
Subject: Fault in RPM & Engine Hour meter
Date Posted: 05 September 2016 at 18:23
Hello Forum,
my Hanse 312 buildt 2004 is equipped with the RPM meter
(picture attached) which also shows the engines operation hours.
Since some time the indicator of the RPM meter often remains on
200 RPM even though the engine is stopped.
The new fault now is the hour meter which only shows fragments of the digits.
So, I have to substitute the entire meter.
The data on the instrument are:
"Siemens VDO  trading Nr. 02 12 195   12 / 24 V"
VDO told me to contact Yamar. So I did. But the spare part they offer is quite expensive.
Has any one out there an additional idea where I could get such a spare part ?
Thanks in advance for your advice.
Sailbonbon
Date Posted: 05 September 2016 at 18:29
You can find them for ~400 $ on ebay.
Happy Hunting
Posted By: JesperBergsjo
Date Posted: 05 September 2016 at 18:33
the blank LCD for the hour meter is a standard error. I'm in my second Hanse with Yanmar engine and both stopped to work after approx 8 years. I have a couple of friends with the same problem. However, there is a method to fix it if you are a "handy man". I attach the instruction how to do it.
http://myhanse.com/uploads/3797/Repair_of_Yanmar_Tach_updated.pdf" rel="nofollow - http://myhanse.com/uploads/3797/Repair_of_Yanmar_Tach_updated.pdf
Jesper
Date Posted: 06 September 2016 at 09:24
Thanks to both of you.
I will try to repair the meter next month as described
in Jespers paper.
Will report about the results.
Sailbonbon
Posted By: 2small
Date Posted: 06 October 2016 at 12:15
We have installed an external hour meter in the Cabin next to the electric panel. The rev counter works mostly correct.
y-u.n
Date Posted: 16 December 2016 at 13:04
Surprise, surprise,
before I followed the repair instruction I searched through the internet and
found a later post from the instructions editor. There he mentioned that
the hour meter after a while again was faulty.
What to do ?
This morning I dismounted the instrument and found an easy solution:
1. Loosen the 3 screws you can see on the back of the instrument
2. Before the screws come out pusch them in direction of the front glas
3.Through this the glas will come off and you can take the instrument out of
its housing.
4. Carefully take the white connector away from the pins on the plate (see picture)
5. Also take out the smal white plastic piece ( its the end of the cable ribbon) of the connector
6. Spray all the connections with a contact fluid
7. Put everything carefull together.
8. Do not use metal instruments to manipulate the electric parts
After this procedure my hour meter shows clear visible digits again.
Best regards
Sailbonbon
Posted By: h315idra
Date Posted: 16 December 2016 at 15:08
My hour counter (Yanmar Panel , 2006 315) works only in summertime LOL, whet the weather is dry. Now I decide to install (by my mechanic) a analogic hour counter inside the motor box, togheter a Emergency engine starter, if you lose or broke the key, or if the electric panel make default.
Alessandro Camerini
315#526
Posted By: Ta'I Miti 2
Date Posted: 18 January 2017 at 14:30
I bought on E Bay an engine hour meter for 7.94€
http://www.ebay.fr/itm/252647447472?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT" rel="nofollow - http://www.ebay.fr/itm/252647447472?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I installed it in the cabin/engine door side panel
Not only those who wander are lost
I've learn that the best way to learn about people is to sail with them
Date Posted: 18 January 2017 at 14:51
If you have to change your RPM meter
You can buy any kind of diesel RPM meter
Even on e bay  ;-)
You plug in on the "W" of the alternator
Over and out
Posted By: Gregor
Date Posted: 19 January 2017 at 06:48
Have look in the other topic on the hour meter in the 312-part of the forum.
Uisge Beatha
Previous boat: Hanse 311 #80
Posted By: Blaven
Date Posted: 03 February 2017 at 16:17
Hi Ta'I Miti
I too would like to install a new meter and your solution seems ideal,however knowing little about electrical equipment I am hoping a picture or basic sketch will help me to identify the "w" terminal
Engine is 3ym30 with 60 amp alternator coupled to sterling regulator
Keith
Posted By: cptgood
Date Posted: 04 February 2017 at 11:02
where from did you get  the + connection for the hourmeter? From the key switch, the alternator or somewhere else?
thanks
Posted By: Forth2
Date Posted: 26 May 2017 at 14:09
Here is one replacement tacho and hour meter that fits quite well in the Yanmar B-panel.
It is from swedish biltema, but the same meter is available from other brands also.
BR Mikael
Hanse 315 - 2006
Posted By: Borjebus
Date Posted: 21 November 2018 at 07:51
Too bad I didn't see your post in advance. I'm a frequent visitor to Biltema but never noticed that they sell things like this. I took the hard way and got a replacement tacho from a Yanmar dealer. The brand is Italian - San Giorgio S.E.I.N. and it's for "W" signal from the alternator.
I took the unit home to make the hour meter run to the old value. I thought by applying 12V to the tacho itself it would start counting. Nothing happens, it's still at 0.8 hours.
Do I need to apply some kind of voltage, or frequency, to the tacho input to get the hours counting?
Posted By: Vetnix
Date Posted: 21 November 2018 at 21:28
Hej,
my front panel has been damaged and I tried to get a spare part in Sweden.
They told me i have to replace all of it.
My old instruments are useless according to them.
About 1000€ just for a piece of plastik.
To repair the Engine hour meter is easy.
You will find a Youtube video to fix it.
How much dit you pay for the original Yanmar spare part? (front panel incl. instruments)
Regards.
Vetnix
Posted By: jeb
Date Posted: 21 November 2018 at 21:48
If it's the hourmeter that is not working you can by a replacement LCD here: https://www.boatstuff.se/display-timraknare.html Hours are stored in the tachometer so no calibration is needed. Fits both Yanmar and Volvo.
499 sek is 50€. If you have some skills in electronics and software you can build your own replacement using an Arduino and a oled display for much less.
Jesper
Hanse 400e
Posted By: Borjebus
Date Posted: 22 November 2018 at 08:29
I actually only replaced the RPM/hour instrument, not the whole panel. The instrument was damaged by moisture - some times the RPM didn't move and the hour meter was at the end never visible. I tried the method found on Youtube but I was not successful.
The Yanmar replacement part (Italian brand now) works well but cost a lot. I would however recommend the Biltema instrument for pricing reasons and not replace the whole panel if other things works OK.
For the winter I brought the whole panel home to make the hour meter run to the correct value. The problem is that I can't get the hour meter to move just by applying 12V to the instrument itself. Do I need to also have some frequency on the "W" input?
Posted By: Vetnix
Date Posted: 22 November 2018 at 15:48
Hej Forth2,
there is still a RPM counter available.
But without the hour meter.
Art nr. 25-8039 for 599 SEK.
Mayby they made some changes in the katalog 2018.
What about Mekonomen?
Vetnix
Posted By: Borjebus
Date Posted: 22 November 2018 at 18:24
The Biltema webpage actually shows that article WITH hour meter.
I got a response from the Italian manufacturer of my instrument - I need apply BOTH 12V power and a frequency to the "W" input to make the hour meter run :).
Posted By: Forth2
Date Posted: 22 November 2018 at 18:43
Hej.
This meter probably fits. Only 50 eur this week.
https://www.marinea.fi/ecms-kierroslukumittari-0-4000-lcd-naytolla-85-mm-musta
Micke
Posted By: Vetnix
Date Posted: 23 November 2018 at 21:10
Hej Borjebus
are you shure.
Please post the Biltema art.nr.
Mvh.
Vetnix
Posted By: Forth2
Date Posted: 24 November 2018 at 15:13
Hej Vetnix.
Actually Biltema has no hour meter in any picture of the tacho.
Not even on the box my Biltema tacho came in.
I just found the box while cleaning my garage.
But in reality my tacho(25-8039) has a hour meter.
So you need to check it from the actual product on the shelf in Biltema.
mvh
Date Posted: 24 November 2018 at 15:35
Originally posted by Ta'I Miti 2 Ta'I Miti 2 wrote:
Over and out
So which is it?
Over or out??Confused
Posted By: Vetnix
Date Posted: 25 November 2018 at 16:26
Hej Borjebus,
I have got one for 599SEK (appr.60€)
The box has a window and shows the engine hour meter.
The manuel is a bit confusing. (both manels, webpage and box)
Without your knowledge I would not dare to bay it.
Thank you for all of it.
Mvh.
Vetnix
Posted By: Vetnix
Date Posted: 25 November 2018 at 16:32
Hej Forth 2,
I have got one for 599 SEK.
Thank you for your assistance.
Mvh.
Vetnix
Posted By: Rock
Date Posted: 25 May 2024 at 15:13
Hi all,
Previously I replaced the LCD hour meter (thanks to the forum !), works fine.
Recently the tachometer started working intermittently, and then stopped working entirely.
In order to not have any potential issues with generic tachometers from chandleries, I decided to buy a Yanmar unit (almost 300 Euro).
However, I can’t get it to work Confused
The new meter has 4 wires, the old one 5 (2x black)
Yanmar dealer saying they are connected inside the unit (probably just the  ‘minus’ wire).
They told me to set the pulse at 10.29, with the pushbuttons on the back, which I did.
The LCD display works, the background lighting works.
But the RPM needle doesn’t move.
When I turn the switch to ‘on’, I feel and see the needle vibrating for some 3 seconds, then it sits still.
When I turn the switch to start, I see and feel the needle vibrate again, but then it stops and stays at  ‘zero’.
The (original 60A Hitachi) alternator works, charges the batteries.
Anybody any idea about what could be the issue ?
This is a picture of the old and new unit.
Peter
Hanse 400e "M-square2" #0241
Posted By: Rock
Date Posted: 01 June 2024 at 14:57
To close my own thread.
I checked the alternator pulse output with a multimeter set on AC. Showed between 15-16 volts, I.e. then Knew alternator worked.
Then followed the orange wire.
Turns out the signal didn’t carry between the last black plug in the engine department and the next black plug near the engine switchboard.
Connected the tachometer directly with the alternator and it worked.
So, will run a new wire directly from the alternator to the tachometer.
Following the same path as the original wiring loom.
What i don’t understand (or like), is why 1 wire in a factory installed wiring loom became faulty. Makes me wonder about the other 7.
I followed the loom and couldn’t find obvious areas with chaff or other kind of wear.
Peter
Date Posted: 01 June 2024 at 15:40
Hello
I've got the same RPM pblm
Can you tell me which alternator output you checked and which one was the problem?
THANKS
Posted By: Rock
Date Posted: 02 June 2024 at 10:11
It’s the orange ‘pulse’ wire.
In case your alternator is the source of RPM input (which I would expect with 2004 engine).
If not the alternator, there should be a sensor on the flywheel (I have no experience with that but believe it’s the same logic, also orange wire coming from tachometer sender/sensor)
I followed the lead of this post on cruiserforum.
BR
Peter
Date Posted: 15 July 2024 at 17:34
I just bought this on Amazon
Looks like the Yanmar one
Caiqinlen
Compteur de tachymètre RPM, tachymètre de pointeur de Bateau Hippo rétro-éclairage Rouge étanche 85mm pour Camion pour Voiture
https://amzn.eu/d/0fXxFYWf" rel="nofollow - https://amzn.eu/d/0fXxFYWf
