  New Posts New Posts RSS Feed - Fuse for “pump with hose”
Relentless View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Relentless Quote  Post ReplyReply Direct Link To This Post Topic: Fuse for “pump with hose”
    Posted: 08 January 2021 at 13:40
On my boat, this pump turns on with F3 button.
I was using it, and then I think I blew the fuse. The F3 light flashes now and I cannot find the fuse location.
Any help??
Thanks!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne's World Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2021 at 16:56
Rob,
The fuse is 30amp and is on the outboard end of the We panel. PM me your email and I will send you the PDF showing the fuses on this panel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Relentless Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2021 at 19:39
thanks Wayne!!
Yep!  I see it now after reading your message and taking a closer look!  It’s buried in the middle of the board!  I had to move the wire bundle to see it!
Thanks a million!
Currently anchored in St Barts.
Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Black Diamond Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2021 at 01:51
Another reason to replace fuses with the "glow when blown" variants.     MUCH easier to find and replace.
I sent the WURTH 12V diagrams I have to your email account.  Hope they help.
Edited by Black Diamond - 09 January 2021 at 01:55
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fendant Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2021 at 03:55
This is the reason why I have replaced all fuses by resettable ones.  I once lost a fuse I had to change and it disappeared into the Würth panel and caused a short circuit on the PCB. This was a 1000€ silly mistake.
marcopone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marcopone Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2021 at 19:22
The F3 pump is also a problem.
It has a rubber propeller who can not run dry.
Besides if it stay off for a long time the propeller locks and the fuse blown.
After having changed several fuses I took it out and replaced with a grey water pump.
This can run dry without melting the propeller.
I also took out the filter as this pump does not need one.
The throuput is lower but you can rely on it when you need it.
bopeddenmark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bopeddenmark Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2021 at 22:45
Hi I have the same problem with a flashing F3. It will help me if you anyone could tell me where the 30a fuse are situated. Thanks in advance. Bo
Post Options Post Options   Thanks (0) Thanks(0)   Quote bopeddenmark Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2021 at 22:49
hi Rope. Could you sent me the PDF document for the F3 fuse
My mail: bopeddenmark@gmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne's World Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2021 at 23:15
Bo,
Emailed you the PDF showing the fuse positions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Black Diamond Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2021 at 00:45
X3.6.   Its probably on page 2 on Wayne's PDF (as it is on mine).    Strongly suggest you use "glow when blown" fuses so that its easier to locate and you only reference the doc rarely.
Edited by Black Diamond - 29 April 2021 at 00:46
This page was generated in 0.262 seconds.
