  New Posts New Posts RSS Feed - 415 control panel wiring
Sean View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sean Quote  Post ReplyReply Direct Link To This Post Topic: 415 control panel wiring
    Posted: 01 May 2022 at 18:46
I need to add and AIS transponder to my Hanse 415. I would like to wire it to the same switch that turns on all instruments.
Down the line I will probably add more electronics using the unused function buttons on the right.
Is there any wiring diagrams or instructions available for this sort of thing?
Sean
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fendant Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2022 at 08:49
Hi Sean,
please PM me your e-mail address
415 Singapore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 415 Singapore Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2022 at 09:20
Hi always worth checking the Diagrams and manuals section, not sure if this is what you need
All the best
Paul
Paul - Night Train - 415 #136
Post Options Post Options   Thanks (0) Thanks(0)   Quote S&J Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2022 at 12:14
My AIS transponder has been added behind the main switchboard and it not easy to get at while sailing.
As there may be times when I do NOT want to show my position I prefer to have it on a separate switch.  Note that my transponder is not integrated into my other instruments and I use the B&G V60 VHF for receiving AIS.
Mine is currently on F5 (XB 5.6).
Matt1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2022 at 12:35
I added mine to a spare F switch for the reasons Stuart says above. Plus, I have output the posn NMEA from it to an old Furuno Navtex which gives me GPS redundancy, but some have WiFi so could be seen on a tablet etc
Sean View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sean Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2022 at 15:05
Many thanks for all the replies. Plenty of reading material to look at.
I will consider putting the transponder on a separate switch as suggested.
Thanks all
Sean
This page was generated in 0.054 seconds.
