  New Posts New Posts RSS Feed - engine hours counter
Wieland1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wieland1 Quote  Post ReplyReply Direct Link To This Post Topic: engine hours counter
    Posted: 05 May 2024 at 10:43
Hi all
this topic relates to the previous from andrew:
the 312 does not have a  fuel gage
but rather than installing one I got used over the years to keep track of
fuel consumption by noting the engine hours when taking fuel.
Unfortunately the engine hour counter has stopped.
Has anybody out there had the same problem and is this difficult to put right?
Thank you in advance for response and advice!
Wieland
Wieland1
H8jer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote H8jer Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2024 at 10:57
Here is how I got it working again. The volvo might also use a hour counter from VDO
Edited by H8jer - 05 May 2024 at 10:59
stownsend View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stownsend Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2024 at 08:45
I've not changed mine on out yet on the 301 but this video should help
https://youtu.be/u_Ho05-qI3I?si=Wph3YksDU7GnQ84Q
and I got a replacement counter from ebay similar to this  ...
Stu
Pat Butler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat Butler Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2024 at 06:38
I just did mine on my Yanmar recently and used this Youtube clip to aid me. https://www.youtube.com/watch?v=u_2qt6MuWGk Quite easy and it appears original hours came back up. LCD cost me AUD 26
"Right Time" Hanse 342 3 cabin, wheel helm, shallow draught. Hull #470
Martin&Rene View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Martin&Rene Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2024 at 09:41
I have done mine also using AKSpeedo from the UK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wieland1 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2024 at 11:36
hi all
many thanks for your helpful responses!
I will get the replacement now and have a go at installing it
(with help from my technically astute  friend Zoltan)
thank you
wieland
Wieland1
Pieterman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pieterman Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2024 at 20:15
Like you, I had to change mine. akspeedo.com
Easy installing and I had a good result.
Ta'I Miti 2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ta'I Miti 2 Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2024 at 12:31
Hello
I had the same problem
1 - Fuel gauge : bought one on aliexpres. 5€
Let it install by the shipyard. 20'
But by the way they cleaned the tank. 3h ;-)
Type diesel tank fuel gauge with levelmeter : 20€
Bought the same for the water tank, but not yet installed
2 - engine hours
Same. Bought one on aliexpress
But linked it very easy on the red light on the panel
As soon as the lights on, the counter starts to count
Type engine hours counter in ali. Same as line 9€
Installed both inside close to the engine
 Both work perfectly since 5 years
Now my RPM counter is dead, will certainly do the same
Not only those who wander are lost
I've learn that the best way to learn about people is to sail with them
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ta'I Miti 2 Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2024 at 12:48
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat Butler Quote  Post ReplyReply Direct Link To This Post Posted: 21 June 2024 at 05:28
Hello Tal'Miti
Do you have a link you could share with me for the water tank gauge you bought?
TIA
Pat
This page was generated in 0.116 seconds.
