  New Posts New Posts RSS Feed - Thru hulls and ball valves
Gale Force View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gale Force Quote  Post ReplyReply Direct Link To This Post Topic: Thru hulls and ball valves
    Posted: 12 August 2022 at 07:09
I am hauling out in a few weeks time and am considering changing thru hulls and valves
My boat is a 2014 and has the white non metal thru hulls with the brass /bronze ball valves.My plan is to go with Tru Design with collars.
If I go this route do I need to change the white thru hulls as well?
Can any one tell me the material of the white through hulls.Are they all one size?
Would be keen to hear from any of you who have done this conversion before.
Best regards to all
Duncan
Dogscout View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dogscout Quote  Post ReplyReply Direct Link To This Post Posted: 12 August 2022 at 07:37
I've not done the conversion, but just recently changed all the thru hulls and seacocks on my 2008 430e to TruDesign.  I had to trim all of the thru hulls to length and in most cases I did not use a collar because of clearance and went to a 90 before the valve.
So in your case.  You'll need to know the existing thread size and have sufficient length on the thru hull.  And the internal nut would have to fit under the collar too.
Adventure awaits
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arcadia Quote  Post ReplyReply Direct Link To This Post Posted: 12 August 2022 at 08:26
Hanse used Trudesign thru hulls with metal ball valves on my 2018 588.
Axel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Axel Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2022 at 12:26
The white thru hulls are Tru Design!
I wonder why Hanse did now use also the valves of tru design. I am going to change the valves of my 2016 385.
Axel
Hanse 385 #434 Nyanga 2
Pzucchel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pzucchel Quote  Post ReplyReply Direct Link To This Post Posted: 15 August 2022 at 06:28
Same with me,  2017. But how do we know that the white seacocks are trudesign? I didn't see any label anywhere.
Hanse588#55
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gale Force Quote  Post ReplyReply Direct Link To This Post Posted: 15 August 2022 at 07:04
I was wondering the same thing and would I be able to just screw the new Trudesign seacocks onto the white thru hulls
Post Options Post Options   Thanks (0) Thanks(0)   Quote Captain Cook Quote  Post ReplyReply Direct Link To This Post Posted: 15 August 2022 at 09:03
Axel wrote:
"The white thru hulls are Tru Design!
I wonder why Hanse did now use also the valves of tru design. I am going to change the valves of my 2016 385."
It is rather obvious, the Trudesign valves cost 5 times as much as the cheap kitchen-brass valves which Hanse continue to put in our boats.
Look at:
-and you can see how your ball-valves look like after 8-10 years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Black Diamond Quote  Post ReplyReply Direct Link To This Post Posted: 15 August 2022 at 10:53
You will find people equally vocal on both bronze and TruDesign.    In my opinion, there are three issues you want to solve:
1.   The degradation of the plastic thru-hull.   The manual and Hanse indicate you need to replace them every 5 years.   To me this is not as serious as the next issue.
2.   The strength issue when putting a lot of torque on the ball valve.   CE says that it needs to take 600lbs of torque before breaking the combination of thru-hull and ball valve.    Hanse says the combination is CE certified, therefore it is supposed to be OK.   To me, however,   I've put a lot less than 600lbs of force and felt like I was about to snap it in cold, fall, weather and I'd rather not take the chance.   To me,  this is because there is no wide base to spread the load.   Its a narrow connection.
3.  The raw water strainer for the AC unit (at least on my boat) screws directly on top of the ball valve and this is one you open and close all the time.   Its a pain to get to and, again,  I worry about it snapping at the wrong time.
If you still have the original ball valve/thru-hull combination,  I strongly suggest that you carry wooden plugs in case something happens and you need to deal with the hole.    The problem is NOT Tru-Design, its the connection of the two pieces.
In my case I replaced them all with traditional groco ball valves and moved/redesigned the AC thru-hull. See pictures.
The TruDesign works well,  and does not have the bonding problem.  Its a stronger set-up than the factory implementation  because it has the wide base/collar set-up.    Either can work just as well in my opinion.
Edited by Black Diamond - 15 August 2022 at 10:56
kipwrite View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kipwrite Quote  Post ReplyReply Direct Link To This Post Posted: 15 August 2022 at 11:48
Duncan,
I'm doing the same project in a few weeks on my 2016 505, all the underwater seacocks and the thru-hulls will be replaced with Groco.
I think you'll find that when you attempt to unscrew the seacock you may well unseat the thru hull, so be prepared to replace them as well. Others on the forum have reported success preserving the true design thru hulls, so your results may vary. Let us know how you make out.
Agree with Rick on the AC sea cock - it is a flimsy design. On my boat it was not bonded, and the sea cock and manifold was suspect after just a few seasons, the sea cock replaced by a Groco unit, the manifold rebuilt, and everything properly bonded.
Harvey
boomjack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boomjack Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2022 at 06:49
I ask the shipyard to replace all seacocks and thru hulls 3 years ago on my 2014 575 by truedesign.
This season i had a rather significant leak on the rear right toilet seacock and realized that this one had not been replaced by a truedesign Angry....
I'm very interested about the air conditionning manifold change, since I did not bring any upgrade on this particular one and am a bit concerned about his condition.
Any idea?
 Thanks!
This page was generated in 0.218 seconds.
