Forum Home Forum Home > Hints & Tips > 460
  New Posts New Posts RSS Feed - insufficient diesel heater.
Sahinsair View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sahinsair Quote  Post ReplyReply Direct Link To This Post Topic: insufficient diesel heater.
    Posted: 02 May 2025 at 20:45
 I had requested a diesel heater to be installed from the factory for the Hanse 460. The heater, which comes for a very high price of €4500, is unfortunately very small and insufficient for the boat. The installed heater is Eberspacher's 2.kw Airtronic for caravans and is sold for around €500. The heater output is only in the saloon and the port WC. We had heating problems in the rooms and especially in the master cabin in the 460 all winter. The first thing we thought of was installing a second heater. Or we are also thinking of extending the pipe to the front master cabin. Does anyone have experience with this?
Keakaka View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keakaka Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2025 at 06:53
Swap for a 4KW model. We had one on our 388 and it was very good.
This is not a rehearsal. Go for it. Kiakaha
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sahinsair Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 07:06
I am plaianning to bring the hose to the master cabin.
Sailing Sufi
jtjk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtjk Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 13:18
In accessory list, there is two different heaters. The one with outlet in one head and main saloon and other one with "hot water ring and outlet in each cabin/head". I wonder, what is the power in second one.
Ian Coverdale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Coverdale Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2025 at 10:27
Previous similar sized 445 models came with Webasto Air Top Evo 5500. 90mm duct from heater at stern to forward bulkhead with 60mm branches to outlet vents. If increasing from 2kW to 4kW model, likely you need to increase the duct sizes. 2kW is far too small!
Ian & Andrea
SV Gabrielle (H445)
Wild View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wild Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2025 at 19:32
The problems with the Webasto-Eberspăcher air heaters are mostly that the ducks are to small (no enough space) and to long for good working.
We have installed “The hot water ring like you call it “ ebersprăcher Hydronic M-II 12.000 Watt  in our 54 feet.It works like a normal central heating system: heated cooling water runs by small tubes (20mm pec ) to heatexchangers with a ventilator  (in each cabin and head we have total 8 (2 in saloon)) with each there one individual thermostats.
This works very fast ,good and warmup fast for more than 15 years now.
We run it also to heat the waterheater when no wall electricity our no need to run the engine our generator (less fuel consumption and noise)
Edited by Wild - 07 May 2025 at 19:34
Belgium
545e#268
Wild View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wild Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2025 at 19:38
Extra in the 2 heads we run the hot cooling water try a chrome tube as a towel dryer-warmer.👍😉
Edited by Wild - 07 May 2025 at 19:44
Belgium
545e#268
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sahinsair Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2025 at 21:26
To spend extra money is painful.
Edited by Sahinsair - 07 May 2025 at 21:27
Sailing Sufi
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sahinsair Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2025 at 21:33
If I would have chance I would choose water Heather one. But dealer didint inform.but ai don't understand why Hanse installing small one.
Sailing Sufi
Etre Jeune View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Etre Jeune Quote  Post ReplyReply Direct Link To This Post Posted: 03 June 2025 at 05:25
Jtjk,
Good to know, i am installing a 5kw Eberspacher hydronic in my 445. Can you tell me, where the furnace is mounted in your boat, please. My set up will have one heater
Mounted in the saloon, 3.6 kw.
And i will heat the water tank, i am swapping out the original water heater for a bigger 40l with dual heat exchangers, so engine and Eberspacher can heat up the water!
R Stock
This page was generated in 0.246 seconds.
