  New Posts New Posts RSS Feed - Lewmar Electric Winch Conversion
boswell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boswell Quote  Post ReplyReply Direct Link To This Post Topic: Lewmar Electric Winch Conversion
    Posted: 14 February 2010 at 18:04
Has anyone converted the ST40 Lewmar main (halyard) winches to electric on a 350? It looks to me that to do so on the starboard side will reduce headroom in the starboard cabin and will interfere with the overhead light fitting and that there is much more room in the port side head/shower area (my boat has the head on the port side behind the nav table). However if the electric winch has to go on the port side the main and jib halyards will require to be transferred from the starboard winch to the port side, which is probably no problem but will take some getting used to. I would be assisted if anyone has done the conversion to electric on a 350.
Boswell
Hanse 350 #336 Sine Die
lukemi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lukemi Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2010 at 18:12
I ordered my Hanse 370 with the a manual winch on port and electic winch on starbord. The electric winch does have a box below deck that houses the motor and relay. I do not have the starbord cabin so this is not much of a problem. My winchs are Harkin (did Hanse change for the 350 to Lewmar?). I think you would be disappointed with performance if electric were mounted on port side. As you indicated, the Main and Jib Sheets are on the starbord track so you would need to cross over companion way to sheet these sails. I've tried it when my electric was not working and it adds tention to the lines and did not do a great job. If you select the port side, you may want to consider moving the Main and Jib.
Stella Maris 370e#166
This page was generated in 0.140 seconds.
