  New Posts New Posts RSS Feed - Main switch effect on battery charging
371#241 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 371#241 Quote  Post ReplyReply Direct Link To This Post Topic: Main switch effect on battery charging
    Posted: 12 March 2010 at 14:21
As the electrics of my Hanse 371 seems to be of a bit of mystery (without any manual) I have started to wonder one quite important question.
Does the mains battery charger charge the batteries if the battery selector switch is on 0 (off) ?
I have also found out that on the nav station main electrics panel the battery monitor shows  zero amps for 2nd set of batteries even though
when measured from batteries all of them seem to give good readings and wires seem to be all in good contact.
Any Advice?
Brightside View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brightside Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2010 at 19:14
HI 371 # 241
On my 371/106 2002 I always switch off both master switchs (same as 0 on yours) when I leave the boat and can confirm the batteries are charged by the mains battery charger.
A simple check is to look at the battery volt meter. With the switch in 0 position; if you have 13.8 volts or greater the charger is charging the batteries. If you have to 12.5 volts or less no charging is taking place.
BiscayBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BiscayBoy Quote  Post ReplyReply Direct Link To This Post Posted: 02 August 2010 at 06:01
Hi On my 371 I have no reading on the second swith on the main pannel, as you my batteries are fully charged, am investingating the issue. have written to Hase, ( nothing back from them) .
The batteries will charge from the mains on 0 as Mike has quite rightly mentioned
\Barry
I have decided to be happy because its good for my health
This page was generated in 0.093 seconds.
