  New Posts New Posts RSS Feed - Heating in rear cabins
samba View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote samba Quote  Post ReplyReply Direct Link To This Post Topic: Heating in rear cabins
    Posted: 04 November 2012 at 12:55
Hi All,
Since I have a big webasto (5000 series), I would like to get heating in the rear cabins and toilet as well.
Does anyone else have this? Can you please explain how you get all the tubes in the cabins and with joints you have used.
Thanks in advance.
Michiel
Samba - Hanse 411 - Bruinisse
Jøvani View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jøvani Quote  Post ReplyReply Direct Link To This Post Posted: 04 November 2012 at 15:12
I do have heating in both rear cabins. I will be in my boat tomorrow and will try to take some photos showing the installation.
Jøvani
Jøvani Hanse 411 #189
Tønsberg
Norway
Bandy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bandy Quote  Post ReplyReply Direct Link To This Post Posted: 04 November 2012 at 20:48
Hi Samba,
The head unit is mounted in the middle section of the rear "bakskist". from there a 120 pipe is running through the wall into the rear cabin on the side were your boiler, dieseltank and waste tank are. Just before the boiler there is a split in 90/60. 90 goes through the wall to the other rear cabin (in my case big locker). 60 goes to jus behind the dieseltank and splits in 60/60. One ends in the rear cabin and one goes through the frame into the toilet and ends just beside the toilet itself.
on the other side there is a split in 90/60. 60 ends in the shower (i have the separate shower) and the 90 goes underneath the kitchen and pops up in the sitting area. I have 2 times 90 openings in the main cabin, the last one is splitted in 90/60, the 60 ends in the forward cabin.
Bandy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jøvani Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2012 at 17:04
Hi Samba,
As mentioned in my earlier writing I promised some photos of the heater installation in my boat. I have a two rear cabin version and only one toilet. I trust the pictures explain it selves. Understand you have a problem with overheating. Just mention the total outlets in my heater configuration.
·         Front cabin
·         Main cabin, two outlets,  can close one.
·         Toilet
·         Both rear cabins
I have never experienced any overheating even if I close both rear cabins outlets.
Hope this can help you.
Regards Kato
3 first pictures are from stearbor cabin, 4 next from port cabin installations
Tønsberg
Norway
Post Options Post Options   Thanks (0) Thanks(0)   Quote samba Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2012 at 09:56
Thanks for the great replies.
@Kato, can you also explain how your setup is in the main and front cabin.
I my case the outlet goes straight to the dining table and it splits over there to the main cabin and the front cabin. The split is underneath the front dining table seating
Greeting,
Michiel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jøvani Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2012 at 12:20
Hello Michiel,
On the first of my pictures the insulated hose goes under the stove and fridge and further to the seat alongside the dining table. The hose goes all the way underneath the bottom of the cupboards.  There is one T connected outlet in the rear corner of the seats. The hose continue and in the seat close to the mast support it split to a smaller dimension hose to the front cabin and a full dimension hose as a second outlet in the main cabin. This outlet cannot be closed. All other out
lets in the system can be closed.
I bought my boat secondhand, but from the original contract I can see that heating system was ordered originally from Hanse so I believe this is their standard arrangement in 2004/205.
Please just revert if you need more details.
Greating
Kato
Tønsberg
Norway
xiaojunznz2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote xiaojunznz2 Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2013 at 09:08
A 747 was halfway across the Atlantic when the captain got on the loud speaker, " Attention, passengers. We have lost one of our engines, but we can certainly reach London with the three we have left. Unfortunately, we will arrive an hour late as a r esult." WOW Gold
Shortly thereafter, the passengers heard the captain's voice again, "Guess what, folks. We just lost our third engine, but please be assured we can fly with only one. We will now arrive in London three hours late." MapleStory Mesos
At this point, one passenger became furious. " For Pete's sake," he shouted, "If we lose another engine, we'll be up here all night!" D3 Gold
Post Options Post Options   Thanks (0) Thanks(0)   Quote samba Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2014 at 21:16
Hi Kato,
What insulation are you using for the pipes? I want to insulate since it get's so hot that plastic is melting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jøvani Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2014 at 13:15
Hi Michiel,
I did respond to your heating/insulation problem, but for some reason my answer is marked with “PENDING APPROVAL”.
I don’t know why this happen??
Kato
Tønsberg
Norway
Peter-Blake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter-Blake Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2014 at 13:42
"Pending approval" sometimes happens (to me also) if you use words which the server identifies as spam. Just check your words and do some changes.
Blake 370
This page was generated in 0.424 seconds.
