  New Posts New Posts RSS Feed - 2 questions
2 questions
371 Hull # 120 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 371 Hull # 120 Quote  Post ReplyReply Direct Link To This Post Topic: 2 questions
    Posted: 27 September 2004 at 15:37
I have the upgraded Volvo Penta 2040 engine with the standard non folding prop.  My engine manual states that I should not have the boat in gear while sailing and when the motor is not in use.
When I am sailing with decent speed, I get vibration from the prop spinning since it is in neutral and not locked in place by being in gear.   The vibration stops when I put the boat in gear.
Anyone know why the Volvo manual says not to do this?   Others have this issue?
One other unrelated question.   While sailing this weekend, something fell from somwhere high on the standing rigging.  Not sure exactly where it came from or what it was.   I happened to be below deck when it fell, but I was told that it appeared to be a very thin silver or white metal/aluminum strip, about 2-3 feet long.   About an inch or two wide and as thin as a credit card.   It bounced off the deck into the water and sunk.  While I have not yet taken a ride up the mast in my bosuns chair to explore, I cannot figure out what it was or where it came from.  Any ideas?
Thanks.  Jon
Eternal Flame View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eternal Flame Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2004 at 15:51
Hi Jon,
The strip...... maybe you have lost the furling "batten" of your headsail. This is mostly a alloysteel thin plate which is used so you can furl the headsail. I lost one the same way... Check you sail"batten"bags.
And for the vibration...indeed with my old Hanse (292) I had the same problem. I put my gear in place. Good luck....or chance your prop into a nice folding one
Happy sailing!
Frank - Eternal Flame
Happy Sailing you all!
Stella*Nova View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stella*Nova Quote  Post ReplyReply Direct Link To This Post Posted: 29 September 2004 at 16:52
Jon,
at my last ship I had a MD 2020 Volvo engine. I remember to read exactly the opposite in the manual. While sailing the gear has to put in. I often forgot to do that and so I know the noise.
By the way, in my Hanse there is installed the new Yanmar 3YM30. When I forget to gear while sailing I have the same noise. After put in the gear, (now) the prop folds and its wonderful quiet.
The other issue: As my last ship was new, some day I heard a "pling" whilst sailing. On deck I found a small metal thing. I was concerned and asked another boat owner. He laughed and told me that it was the back-pin of a rivet.
You wrote, your lost thing was 2-3 feet long, do you really mean feet or inches?
Kind Regards from Cologne
Ralf
Post Options Post Options   Thanks (0) Thanks(0)   Quote 371 Hull # 120 Quote  Post ReplyReply Direct Link To This Post Posted: 29 September 2004 at 20:08
Ralf and Frank:
As to the engine issue, the Volvo Penta operator's manual for the MD 2010, 2020, 2030 and 2040 states on pg 21 (for those that may want to see this in the manual) that "When sailing, if the boat has a fixed propeller the control level must be in the neutral position when sailing.  If the boat has a folding prop the control lever must be in the astern position."
When I take out of neutral and put in gear while sailing, my vibration stops, but the manual says not to do this, so not sure which is worse.  I think Frank has the right idea, buy a folding prop.....
As to the other issue, the object that bounced overboard was 2-3 feet long, not inches.   Again, I think Frank got it, probably a batten from the self tacker.   I have not been at my boat this week but will check for the missing batten this weekend.
Thanks for the help.
Regards.  Jon
iemand View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iemand Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2004 at 08:10
I have a Hanse 312 with a Yanmar 2GM20. While sailing I sometimes have the problem that I'm not able to put in the astern gear. than I use the forward gear. In my oponion that's the same for the saildrive:just stop turning! What do you think?
Kind regards from Berlin,
Thomas
Martijn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Martijn Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2004 at 10:59
Hello Thomas,
I think your right when you have a fixed propellor. On my other boat it was the same. I had a fixed propellor and put in the forward gear while sailing. Only that was no saildrive. But It is strange you can not put the gear in astern while sailing. But in my opinion it works bothways. Now I have a 3 blade folding propellor and now I must put the gear in astern position so the prop is folding. According the books from Volvo.
greetings,
Martijn "NO FEAR"
Edited by Martijn
franko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote franko Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2004 at 21:07
Hello All,
As a matter of interest, a rotating propeller creates more drag than a stationary one (only when sailing of course) This because a rotating prop presents a 'disc' to the water flow over it. (i.e. greater projected surface area)
Now, does anyone of you know why Volvo say to leave the gear in neutral when sailing? I always select reverse myself.
What folding props do y'all recommend for the VP MD2020?
Cheers.
Pic attached of my boat earlier today having her bum washed - taken with my new toy - Sony Ericsson camera phone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Martijn Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2004 at 22:56
Hello Franko,
Well I think if you want to know it for sure which foldingpropellor you should use please ask your Volvodealer about it.
I have a Hanse 341 with a Volvo 2030. In combination with a 3 blade folding propellor. I am very happy with this combination because You have 33% more power compared to a 2-blade foldingpropellor. That is very nice in harbours. Your boat responds almost imediately like a fixed propellor. Also backwards. But I do not know if it work out the same way with the Volvo 2020. But it is certaintly possible because Hanse do offers this in their optionlist. It will cost around the 1500 euro's or something.
But I thought the standard engine was 30HP for the 371???
greetings,
Martijn "NO FEAR"
Edited by Martijn
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stella*Nova Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2004 at 10:20
Franko,
at my 341 there is istalled a 3 Blade folding prop. I'm very happy with that. The difficuties older folding props have are not shown at my model. Its a Flex-O-Fold and it has a very good reaction when stopping in the harbour. When driving with engine you don't hear any prop noises like fixed props sometimes have.
Dancin' Fool View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dancin' Fool Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2004 at 10:22
Hello all,
The story about the drag which is produced by a rotating prop is not completally accurate. Nature has it's way's and will try to go the direction with the least resistance. Naturally there is a moment (speed/revolutions) that the drag caused by the rotation of the propellor will dramatically increase.
So it can be interesting to check out you boat speed in different conditions. Or as Frank already sujested, mount a foldingprop.
Michael
This page was generated in 3.028 seconds.
