  New Posts New Posts RSS Feed - Anchor Windlass
Anchor Windlass
 Post Reply Post Reply Page  123 5>
blackswan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blackswan Quote  Post ReplyReply Direct Link To This Post Topic: Anchor Windlass
    Posted: 24 November 2017 at 22:00
The switch for the anchor windlass got wet and shorted so that the windlass ran whilst sailing.
This caused the clutch on the windlass to burn out, so the windlass slips when we want to raise the anchor.
I am trying to take it apart for a rebuild, but the windlass itself is seized on.
We may have to replace the Lewmar windlass on our 400. Is there any way to get to the bolts and the back of the switches without cutting a hole in the liner from the forward cabin?
Jens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jens Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2017 at 13:43
I moved my windlass to the front last year. To get it off I cut a hole in the side and after winch was removed I covered the hole with a fiber plate sealed with Sikaflex. It was quite easy to dismount the winch, so maybe you can buy a smaller standard hatch as I have in the front of the anchor locker.
Jens
Hanse 370, #423, 2008
Three cabin
Post Options Post Options   Thanks (0) Thanks(0)   Quote blackswan Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2017 at 23:11
Thanks Jens, thats exactly what we thought we would have to do, cut a hole to remove the switched and cover it over, also cut a hole if we need to replace the winch.
Not exactly a maintenance friendly design is it?
astarte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote astarte Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2017 at 15:46
Jens,
Interesting, was thinking of the same with my 370. How did you run the cables forward to the new position? How is the steel framme for the windlass fastened? To the inner liner or to the hull?
Kristoffer
Hanse 370e #412
jeb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeb Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2017 at 18:01
Hi, I recently fitted a windlass in a semilar way. To secure the shelf I used rectangular aluminum bars glued to the back of the liner. I drilled holes thru the shelf and the liner. I drilled and tapered holes in the aluminum bars using the shelf as template. Then i glued the aluminum bars with sikaflex and secured them using the mounting bolts (M8). Access was tight thru the inspection hatch. When the sika was cured I finally mounted the shelf. Cables were routed the same way (between liner and hull) and finally thrue the bulkhead.
Jesper
Hanse 400e
landlocked View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote landlocked Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2017 at 23:46
Here are some photos of the similar mod I made seven years ago.  Removing the windlass was not so difficult because on my model year (2006) Hanse used an aluminum bracket rather than a molded base for the windlass.   I recall using a blowtorch to release the sikaflex to remove the old bracket, but the windlass bolts were all accessible.
"Kerkyra" 400e #042
moss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote moss Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2020 at 21:49
could you give any advice on which model of windlass should/could be installed? do you think the symmetry matters in case it has to be installed on portside or starboard?
I found the two following ones
1. this is "recommended" for H415, currently installed by Hanse
2. this is recommended for H400, seems it WAS installed in the past
brand is Lewmar, no details on model are available, significant difference in price.
Could you please give any advice?
thanks in advance
Gian Paolo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Captain Cook Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2020 at 10:30
Lewmar Pro Series 1000 12V was mounted in my boat in 2006
Edited by Captain Cook - 21 January 2020 at 10:37
moss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote moss Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2020 at 11:42
Thanks for the reply! 13 years later still working. Do you know also what device to use to control this system? button with a line, other?
any advice between Lewmar or Quick? Size should be the same
Post Options Post Options   Thanks (0) Thanks(0)   Quote Captain Cook Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2020 at 19:58
Try Google:
https://www.lewmar.com/Lewmar-Files/Manual_Pro-series-fish-manual-G3_B10414%20iss1.pdf
In this manual you can read about my model, and in the wiring diagram you can see that a contactor, an automatic curcuit breaker and a main curcuit breaker are needed.
If you look at the pictures above, you can see the operating gizmo supplied by Hanse, I have furthermore installed an up/down switch  at the steering pedestal.
Picture here under: Contactor in the middle, curcuit breaker marked Anchor under this.
I have mentioned this quite a few times before, and it concerns all myhanse members: Publish your Flag, Hanse Type and Hull # as a minimum in your posts. It is  a nicer style, than if  your are  anonymous.
Edited by Captain Cook - 22 January 2020 at 23:00
This page was generated in 0.137 seconds.
