Forum Home Forum Home > Hints & Tips > 400
  New Posts New Posts RSS Feed - New seacocks/thru-hulls
 Post Reply Post Reply Page  123 9>
 Rating: Topic Rating: 1 Votes, Average 5.00  Topic Search Topic Search  Topic Options Topic Options
Captain Cook View Drop Down
Post Options Post Options   Thanks (2) Thanks(2)   Quote Captain Cook Quote  Post ReplyReply Direct Link To This Post Topic: New seacocks/thru-hulls
    Posted: 20 January 2018 at 14:55
The old topic "Seacocks" is already discussed in detail, a search just now gave 100 results. In the old subjects you can find members who stubbornly claims, that at least their seacocks were made of bronze, and then after a test must admit that the yellow material is brass. Hanse werft has maybe not been completely honest with the owners who by telephone have been assured, that the thru-hulls and seacocks were made of bronze.
Later inquiries have earned an answer, that the material was DZR-brass, by some called "marine grade" brass. Brass is made by copper and zink, and the DZR has been added other metals to slow down the detoriation. The DZR was chosen because it is cheaper than bronze or Trudesign. In the pictures below you can see my old thru-hulls, which when replaced after seven years in 2013, still had a pretty good look. Notice the red ring in the yellow brass, where detoriation has started.
My old ball-valves marked DN20 (Diametre Nominal), were the type your plumber mounts in your house (plain chrome-plated brass I suppose). Those were in my boat a bit rusty in the handles but otherwise seemed OK.
My decision to change the seacocks came after the horror stories in 2012-13, where several boats from many different shipyards had unwanted fountains in their boats.
The change from DZR to bronze or Trudesign is not that costly, so the Hanse-owners with a 8-12 years old ship should maybe change the seacock/thru-hulls now?
If not, I advise to buy wooden plugs to place near the "fountain-to-be".
This is not an attempt of mouth-to-mouth rescue of the old tread, but basicly an friendly advice
to the owners of old Hanses, which still have not changed their thru-hulls.
Regards Kjeld
Edited by Captain Cook - 24 February 2021 at 11:04
StavrosNZ View Drop Down
Rear Admiral
Rear Admiral
Post Options Post Options   Thanks (0) Thanks(0)   Quote StavrosNZ Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2018 at 21:38
Good move, i replaced all of mine on my 2010 400 a few years back and posted the process on the forum, its real piece of mind to know none of the DZR brass remains below the waterline.
The irony is that Trudesign fittings are cheaper than Brass particularly in the volumes Hanse would buy. Hanse now fit Trudesign skin fittings on all new boats but then fit DZR brass ball valves and tails to these. Hopefully at some stage they will go the whole hog and fit the full synthetic package, i as a prospective buyer would see this very favorably over other brands still using Brass.
Stephen
Sea-U View Drop Down
Commadore
Commadore
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sea-U Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2018 at 09:49
I too changed all 2 years ago. I did not like the Trudesign 90 degree bend (in middle of picture). It was of a small inner diameter.
I then bought a stainless steel bend. I have now learned that this was a big mistake. Stainless steel can be worse than brass.
Have just received a bronse 90 degree bend for the black water. Hope I can change... or I might need to buy new seacock too.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Captain Cook Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2018 at 10:41
At the internet you can google hundreds of posts about corrosion of seacocks. The Danish Sailing Association homepage (http://www.sejlsport.dk/baadejer/praktisk-viden/skrog/skroggennemfoeringer/korrosion-i-skroggennemfoeringer) complains about EEC-directive 94/25EC, and links to a report from Piet Jansen, FORCE Technology (published 2004!)in danish. I will summarize some of his conclusions here.
Bronze (CC491-CuSn5Zn5Pb5=85%Cu,5%Sn,5%Pb) is corrosion safe in molded parts.
MS58 Brass (CW612N-CuZn39Pb2=59%Cu,39%Zn,1-2%Pb) is not corrossion safe.
(Prone to de-zinkification, vulnerable to strain-corrosion in salt water).
Special Brass (DNZ) (CW602N-CuZn36Pb2As=62%Cu,36%Zn,2%Pb,<1%As) is fairly corrosion safe.
It is vulnerable to strain corrosion.
Stainless steel AISI304 (A2) is not recommended.
Stainless steel AISI316 (A4) is better than MS58, but in 2-5 years come pitting and fissure corrosion.
Stainless steel SS254 is okay, but very expensive.
Jansen tells that a reddish colour in the yellow brass is a symptom of de-zinkification.
I just now discovered, that 94/25/EC is repealed, and instead as of January 18, 2016 a new directive 2013/53/EU is in force. 65 pages to study for the Hanse owner. I just skimmed the directive for any mention of seacocks, but I found no such thing.
Edited by Captain Cook - 24 January 2018 at 13:06
iemand View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iemand Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2018 at 21:01
   I'm planning to change to true design on my 370 as well. What have you done on the SD50? TD is still missing a double nipple....
Commadore
Commadore
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sea-U Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2018 at 21:30
When I changed mine 2 years ago, the piece that is in the hose was totally gone. The hose almost fell of by itself. I was just lucky ... and the boat is from 2008.
The other parts were reddish halfway through.
So iemand !!! You should start to be worried!
Rear Admiral
Rear Admiral
Post Options Post Options   Thanks (2) Thanks(2)   Quote StavrosNZ Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2018 at 21:45
yes i did the valve on SD50 as well including glass filled nylon male to male to connect the ball valve to the saildrive. 4 years no problems, see mt earlier posts:
http://www.myhanse.com/sd20-saildrive_topic9673_page2.html
Stephen
Rear Admiral
Rear Admiral
Post Options Post Options   Thanks (0) Thanks(0)   Quote StavrosNZ Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2018 at 21:49
used glass filled nylon male to male made by hansen, see www.hansenproducts.co.nz, used Sika 291 on both threads fitted when cold.
Stephen
Rubato View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rubato Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2018 at 17:53
I know very little about the TruDesign product and the material it is made out of. Is there a greater chance of getting cracking from water freezing in cold weather versus a metal part? The basin where the boat is moored is fed by a fresh water creek making the top layer much much less salty and it freezes easily in the winter.
Hanse 400e, #168
Post Options Post Options   Thanks (0) Thanks(0)   Quote Captain Cook Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2018 at 18:24
Nippel in bronze from http://tempobaadudstyr.dk
This page was generated in 0.098 seconds.
