Substitution of keel |
Post Reply
| Author | |
Raniero
Quote Reply
Topic: Substitution of keelPosted: 09 February 2024 at 19:01 |
I would change the bulb (2,85m) with a shorter(2,45).
Anyone knows the costs? The mast remain the same?
Wayne's World
Joined: 18 July 2012 Location: Cruising Status: Online Points: 1434 |
Quote Reply
Posted: 09 February 2024 at 19:38 |
Raniero,
Go to the Hanse Shop at www.hanse.boatoon.com they list 3 keels for the 548 of different weights - a deep T type at 5800kg, a "standard" L type at 6377kg and a shoal draft L type keel of 6620kg. I think you will find the mast height remains unchanged but the shallower option keels are heavier. They don't list prices for these on the website so I guess you need to email them.
Cruising, currently in the Pacific until the end of 2026. |
Raniero
Quote Reply
Posted: 09 February 2024 at 19:48 |
I have a 545 not 548
Captain Cook
Joined: 23 May 2006 Location: Denmark Status: Offline Points: 1245 |
Quote Reply
Posted: 09 February 2024 at 19:51 |
The cost af a new keel is €25000????, and I doubt that the market for the old keel is great? The prices here may give you an idea: https://hanse.boatoon.com/en/shop/suche - and since most of the keels here are not priced, you can ask Boatoon for a quote. In my opinion the smartest solution is to sell the old boat, and purchase another new/used Hanse with shallow draft. Especially in the Netherlands there are quite a few boats with shallow draft around the water that was called Zuiderzee when I was younger. (Today IJsselmeer/Markermeer). My Hanse 400 has a draft of 2 meters, so I had to avoid shallow parts of that area when I visited in 2012 and 2015. :Kjeld
Edited by Captain Cook - 09 February 2024 at 19:57 |
Ratbasher
Vice Admiral
Joined: 31 May 2017 Location: Cyprus Status: Offline Points: 818 |
Quote Reply
Posted: 10 February 2024 at 06:56 |
I completely agree with Kjeld: buy another boat. There are all sorts of calculations that underpin the selection of a particular keel and I would very strongly advise you to seek advice from a suitably qualified and experienced professional if you still want to research that route. Anything less is a gamble with your boat and those on it.
Raniero
Thanks(1)
Quote Reply
Posted: 10 February 2024 at 08:02 |
Another solution may be change my 545 with another 545 with shorter Keel . If there is someone that want do this change . My boat is in Adriatic sea .
S&J
Joined: 30 August 2014 Location: Perth WA / Med Status: Offline Points: 1371 |
Quote Reply
Posted: 11 February 2024 at 03:19 |
I have some sympathy. I am somewhat surprised to see the standard draft for the 545 is 2.8m. My very first experience of the Hanse brand was a 470 with a 2.35m draft based in Fremantle, WA. The main "destination" for sailing around here is Rottnest which has very limited moorings or anchorages for a boat with this draft. I enjoyed a great cruise with the owner to the Abrolhos Islands off Geralton, but the owner only kept the boat a couple of seasons before swapping for a catamaran.
So far I haven't found the 2.25m draft of my 458 an issue anywhere in the Mediterranean although my depth reading was zero when we went into the harbour at Nisyros last season. |
Wild
Vice Admiral
Joined: 18 March 2010 Location: Turkey-Greece Status: Offline Points: 937 |
Quote Reply
Posted: 26 February 2024 at 19:33 |
I am not surprised of the 25.000 euro for the 2,43 keel.
When we ordered our 545 in 2010 the extra cost for the 2,43 keel =13.000 euro The 2,43 keel upper part is cast iron and the lower part lead.The 2,80 is complete cast iron and so far I remember in one part. I happy we ordered the 2,43 a 2,80 in the small harbor’s of the Med. is a pain in the …![]() |
Wild and Wet
Belgium 545e#268 |
Raniero
Quote Reply
Posted: 26 February 2024 at 19:46 |
Actually the cost for the substitution of the Keel is 40-45000€
Black Diamond
Joined: 24 October 2015 Location: Newport, RI, US Status: Offline Points: 1275 |
Quote Reply
Posted: 27 February 2024 at 01:06 |
Have you checked with the Mars Metal people? They make keels to replace the factory keels for a lot of boats. In general, they are much higher quality and can provide sailing stability with less draft. If I was going to buy a new keel, I'd look there before Hanse. This is who I was dealing with a while back.. William Souter Custom Keel Sales & Design……….Ext 129 MarsKeel Technology® (905) 637-3862 | (800) 381-5335 | FAX (905) 637-8841FWIW |
S/V Black Diamond Hanse 575 Build #192, Hull# 161 Newport, RI |
Post Reply
| Tweet |
