Forum Home Forum Home > Hints & Tips > 460
  New Posts New Posts RSS Feed - SIMARINE SPC220H Contro Panel
Velamarco1959 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Velamarco1959 Quote  Post ReplyReply Direct Link To This Post Topic: SIMARINE SPC220H Contro Panel
    Posted: 17 February 2025 at 15:47
Hi everyone, I have a problem with the Simarine Panel. On my boat Hanse 460#129 are installed 6 LiFos lithium battery model LiFePo4 105 Ah. When the boat arrived from the shipyard the parameter of battery service panel weren't set and the battery display show 75% regardless of battery status. Can any other hanse owners with the same type of control panel and batteries help me?
"Betta"
Hanse460
Marco
jtjk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtjk Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2025 at 12:26
As a new member of the forum I am just guessing, but can it be attached only to the starter battery or is there separate values for both banks?
Br,
Janne
ariette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ariette Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2025 at 20:39
The Simarine panel doesn’t work with lithium. Mine shows 75% all the time too. The mastervolt panel is the one to use. I have another similar issue with batteries
I leave the Simarine panel on over winter so my concierge can use the transom. Solar power keeps the batteries in charge at around 80% but after a couple of weeks the blue sky system switches of the Simarine panel and puts what it can to sleep. Is this a feature of the system?  Sentinel live data shows no problem with the batteries but the “deep sleep” feature seems to switch on regardless of battery health. Ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ariette Quote  Post ReplyReply Direct Link To This Post Posted: 23 February 2025 at 07:57
Hi. To answer my own question above the dealer has now told me that after 2 weeks inactivity the boat puts itself into "deep sleep" to preserve battery life. To switch on the BluSky switch has to be activated. It would have been a good idea to put this feature in the manual.
akbulut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote akbulut Quote  Post ReplyReply Direct Link To This Post Posted: 26 February 2025 at 13:30
Hi, you will need to install Simarine Shunt (SC303 or SC503) to show the battery % - SOC value (State of Charge) for lithium batteries, you will be also able to see charging or discharging amperage currents as well.  (https://simarine.net/combo-shunts-sc303-and-sc503/
Edited by akbulut - 26 February 2025 at 14:03
Sahinsair View Drop Down
Lieutenant Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sahinsair Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2025 at 22:13
I have installed also Extra shunt for Simarine. I Wonder why Hanse doesn't install this shunt. Simarine Pico is also not connected to the NMEA 2000 cables. So you cannot get some of the information from the boat. If you can connect the internet you can get all of the informations from away. This days Simarine has a new update. But it needs to install with computer. I am using #Vanemar in my boat. Vanemar is saying that after this update you can control all of the buttons from away as well.
Sailing Sufi
460AUS View Drop Down
Lieutenant
Lieutenant
Post Options Post Options   Thanks (0) Thanks(0)   Quote 460AUS Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2025 at 06:13
Hi All,
On later 460's (mine is #209 Manuf end 11/24) they have 3 Simarine shunts fitted ex factory. Engine, House and Bow Thruster, and they can all be read from the main panel.
It also connects to iPhone. I have not taken delivery yet but when I do I will see what the iPhone App has to offer, and will post it.
J
angorsan View Drop Down
Lieutenant
Lieutenant
Post Options Post Options   Thanks (0) Thanks(0)   Quote angorsan Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2025 at 09:46
Does anyone know if it is possible to transfer the Simarine data to the be available in Sentinel app?
WBR,
A.G.
Ryantoleary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryantoleary Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2025 at 11:02
Hi there. I was wondering if you ever got this resolved? I took delivery of the Hanse 410 last September and have two lifos 200 Ah batteries but have same problem. They always show 75% on PICO panel. The dealer changed the settings to indicate the correct battery type but no change?
Darek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darek Quote  Post ReplyReply Direct Link To This Post Posted: 13 August 2025 at 16:32
I had the same problem with 75% and 6 lifos batteries. And now i still have the same problem with 3 liontron batteries, after Hanse replace the 6 once. Simarine Pico shows wrong information and apparently the reason is the missing specific Simarine shunt for lithium. Hanse should fix this in this or other way. I‘m also discussing it with my dealer.
Darek "Summertime" Hanse 460 #92
This page was generated in 0.138 seconds.
