Forum Home Forum Home > Hints & Tips > 385/388
  New Posts New Posts RSS Feed - Cockpit floor cover over rudder -385
JavesDK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JavesDK Quote  Post ReplyReply Direct Link To This Post Topic: Cockpit floor cover over rudder -385
    Posted: 29 July 2025 at 15:51
Hanse 385 - The cockpit floor /cover over the rudder quadrant and pilot motor is very soft and bending when standing on the front part of it.  Previous owner have removed the four screws holding the  cover in place, and they should of course be replaced. Has anyone had similar problem and found a solution to reinforce the cover?
marsella View Drop Down
Rear Admiral
Rear Admiral
Post Options Post Options   Thanks (0) Thanks(0)   Quote marsella Quote  Post ReplyReply Direct Link To This Post Posted: 29 July 2025 at 22:06
Same here, but not a problem so far. Of course screws are neededWink
FrankS View Drop Down
Lieutenant
Lieutenant
Post Options Post Options   Thanks (0) Thanks(0)   Quote FrankS Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2025 at 11:12
I had the same problem on my 345.
I reinforced the downside with a piece of bankirai (hardwood), embedded in epoxy and polyester sheets. This solved the problem.
Be aware not to impede the movement of the rudder/autopilot by a too big reinforcement.
Hanse 345 2016 "STYX"
Post Options Post Options   Thanks (0) Thanks(0)   Quote JavesDK Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2025 at 20:06
Thx. Will give this a go and also try to add sypport on the front side. Either with a list or with some type of dowels and then a hole on the floor side. Will post here when done.
This page was generated in 0.102 seconds.
