Forum Home Forum Home > Hints & Tips > 300 / 301
  New Posts New Posts RSS Feed - Rudder lock
Rudder lock
Mergus View Drop Down
Lieutenant
Lieutenant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mergus Quote  Post ReplyReply Direct Link To This Post Topic: Rudder lock
    Posted: 25 August 2025 at 18:28
Hi all
After renewing my rudder bearings I've encountered an counter problem. The rudder is not loose, but it is so smooth that the tiller turns also in harbor very easily when there is any water flow. I'd like to lock the tiller/rudder when in docks to e.g. reduce the boat movement when in anchor. However the only clever way to do this that I've found is to tie the tiller to the cleats (or somewhere else) that means that the tiller cannot be in the up position to enable more room in cockpit.
Has anyone found any clever solutions to this?
What I am currently thinking is to drill a hole and make threads to the upper bearing housing and then put a screw there to "lock" the rudder axle when not in transit
This page was generated in 0.140 seconds.
