Forum Home Forum Home > Hints & Tips > 311 / 312 / 315
  New Posts New Posts RSS Feed - Hull to deck sealant.
j_ohnno View Drop Down
Lieutenant
Lieutenant
Post Options Post Options   Thanks (0) Thanks(0)   Quote j_ohnno Quote  Post ReplyReply Direct Link To This Post Topic: Hull to deck sealant.
    Posted: 01 October 2025 at 07:18
Hello all. Another 2020/315 question for the knowledgeable people here. The external bead of sealant in the hull/deck join is shrinking and hardening. I wonder if anyone knows exactly what brand and type of sealant is used there so I can replace like with like Thank you.
Wayne's World View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne's World Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2025 at 09:05
Johnno,
Originally is likely to be Sikaflex 295UV. It needs replacing every 3-5 years depending on your sailing area.
Mark_J1 View Drop Down
Rear Admiral
Rear Admiral
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark_J1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 October 2025 at 14:08
Don’t know where you are in the world however builders merchants in the UK supply a sealant/adhesive called CT1. That’s a far better option than the original Sika. Lasts longer & easier to apply. Even sets in wet salt water conditions.
This page was generated in 0.072 seconds.
