Rubber seal around portlight |
Post Reply
Page 123 4> |
| Author | |
Johan Hackman
Admiral of the Fleet
Joined: 24 August 2005 Location: Sweden Status: Offline Points: 4361 |
Quote Reply
Topic: Rubber seal around portlightPosted: 10 August 2013 at 21:38 |
The rubber seal around one of the portlights has come off and I don't know the proper cure for it. I don't even know how it was attached in the first place. Glue? Glue would be the way I would try to put it back but would like to ask if anyone has solved a similar problem before or has a better suggestion.
Jøvani
Joined: 20 April 2009 Location: Norway Status: Offline Points: 175 |
Quote Reply
Posted: 11 August 2013 at 07:56 |
Had the same problem 2 years back. I used glue, but don't remember the type. Just put the seal in place with the glue and closed the portlight to get some presure while drying. Sine then it has been in place. However, not longer allowed for kids to pull things in and out of the portlight
Regards Jøvani |
Jøvani Hanse 411 #189
Tønsberg Norway |
franko
Rear Admiral
Joined: 24 June 2004 Location: Sweden Status: Offline Points: 597 |
Quote Reply
Posted: 12 August 2013 at 17:31 |
Johan Hackman
Quote Reply
Posted: 12 August 2013 at 18:37 |
What about contact glue?
Johan |
skipper
Vice Admiral
Joined: 16 February 2008 Location: Sweden Status: Offline Points: 825 |
Quote Reply
Posted: 12 August 2013 at 23:14 |
remember that I fixed a leakage on a fixed side window on the car with some black glue/sealing bought a petrol station. that black sealing could be used here aswell
Skipper Former owner of Hanse 342 2005 (Sparcraft mast, white hull, wheel steering, deep draft keel, short rudder) |
Johan Hackman
Quote Reply
Posted: 05 January 2014 at 13:36 |
Contact glue didn't work but I have friends that have recommended this: http://www.hatchmasters.com/product_info.php?cPath=205&products_id=180&osCsid=356998c896a013e73e2de0e2bec233c3. I might try it and will let you know if I am happy with it. Johan Edited by Johan Hackman - 05 January 2014 at 13:38 |
Johan Hackman
Quote Reply
Posted: 15 September 2015 at 16:22 |
After having been in contact with Lewmar, this is the seal I need: http://www.lewmar.com/products.asp?id=8728&lid=24807. It's quite expensive, though.
Johan |
robh
Joined: 30 March 2005 Location: United Kingdom Status: Offline Points: 251 |
Quote Reply
Posted: 15 September 2015 at 20:56 |
Are you sure the portlight is by Lewmar? And will the portlight not come apart to enable you to relocate the seal and rebuild, as the ones on my 341 do? Mine are a dutch make and replacement parts are a lot cheaper, I also believe better quality than Lewmar. I don't have the details with me but I will be down on BH later this week and can send you the details if that helps?
Rob "Blue Horizon" Hanse 341#113 Portsmouth Harbour UK |
Johan Hackman
Quote Reply
Posted: 15 September 2015 at 21:13 |
I am sure that the portlight is by Lewmar as it is printed on the acrylic. However, I am not sure whether the seal needs to be replaced but that's what I am told. My thinking is that in ten years time the rubber gets dry but I might be wrong.
Johan |
SausalitoDave
Commadore
Joined: 13 October 2014 Location: Sausalito Status: Offline Points: 366 |
Quote Reply
Posted: 15 September 2015 at 23:21 |
I would suggest "automotive trim adhesive". It is used to secure rubber window seals on automobiles and should hold up to weather and salt. It should be easily available at most automotive stores. Sold in squeeze tubes, black, and quite inexpensive.
Post Reply
Page 123 4> |
| Tweet |
