  New Posts New Posts RSS Feed - Charging phones in fore cabin
Johan Hackman View Drop Down
Admiral of the Fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johan Hackman Quote  Post ReplyReply Direct Link To This Post Topic: Charging phones in fore cabin
    Posted: 03 December 2016 at 10:37
With today's need to charge your mobile phone overnight I have been thinking of fitting sockets in the fore cabin for some time. My daughter often plays on her iPad when we are sailing and I use my mobile phone as an alarm clock and I need it to be fully charged in the morning before going to work.
After having contemplated whether to use a cigarette socket or USB I decided to go for the latter and would like to share my experience with you.
I have one USB socket on each side and I take the electricity from the two reading lamps. The cabinets are built in such a way that there is 50 mm space between the outer wall and the inner one. This can be seen in the below picture where I have drilled the hole, so there is room for the cable and the socket itself. There was no need to drill a hole all the way through into the cabinet.
I plan to add switches to the sockets as I don't want and idle current.
Edited by Johan Hackman - 03 December 2016 at 10:39
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johan Hackman Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2016 at 10:42
This is the result:
r schupak View Drop Down
Commander
Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote r schupak Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2016 at 12:29
Hi Johan--Interesting idea & one that I was also thinking of (& adding an additional 12 v outlet in the cockpit). More & more I am using Wifi with my Raymarine a7 GPS / chartplotter which can transmit anywhere to my ipad. I use it on my pedestal but have been limited by the ipads battery. I can control the GPS with the ipad & have also done so while in the cabin (waiting to try it from the head LOL). If any one has installed an outlet in the cockpit (especially of a type 341) or has any ideas please let me know.          Robert
Robert Schupak
Mamaroneck,NY
2004 341
Getting old is inevitable;growing up is optional !!
skipper View Drop Down
Vice Admiral
Vice Admiral
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipper Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2016 at 16:45
Hi Johan,
thanks for sharing this idea, like the simple solution and agree on that we don't want to waste el. energy so a switch is needed.
Searched and to my big surprise does Hjertmans in Sweden have one USB outlet with a switch from Båtsystem (model called Frilight).
Cost around 58 Euro
Skipper
robh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robh Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2016 at 20:00
Great idea Johan,
I have a mains socket in the forward cabin for fast charging my Samsung android phone and tablet. I also have a 12volt socket for using a car type charger with a USB lead and have been thinking for a while of installing a mains socket with a USB socket. This option gives me the USB outlet that I can then use when not connected to the mains, however, I need to find a surface mount USB like you have fitted that has the adaptive fast charging facility.
Rob
"Blue Horizon" Hanse 341#113 Portsmouth Harbour UK
robh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robh Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2016 at 20:36
Robert,
I have a car cigar lighter socket and LED lamp installed on the back of the instrument pod on my wheel pedestal that work fine. I like the cigar socket better in the cockpit as it is useful for a variety of things giving 12volts where the USB only provides 5volts. I suppose you could have both once you have run in the cables, if that suited your needs. I run the 12 volt feed from the saloon power board (12volt power plug fused switch position on bottom right) using a mousing wire in the ducting that runs from the saloon to the port rear cockpit locker at the same time as I run the control wire for the bow thruster. Once in this locker its fairly easy to run these wires under the cockpit floor to the pedestal pod. However, you will have to push a mousing wire from the hole in the port side tube of the pedestal, which is inside the pod down and under the floor into the rear cockpit locker. Once you have done this you can tape the feed wires to the mousing wire and pull them the rest of the way into the pod. There is only one little issue you may come across and that is you will most likely need to loosen the wires in the pedestal tube as in my pedestal the factory had injected a quantity of sealant into this tube around the wires. This took a while to dig out but dependent on the size of the wire you want to install you may be able to get through without a fight.
Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johan Hackman Quote  Post ReplyReply Direct Link To This Post Posted: 04 December 2016 at 16:47
I just measured the idle current of my USB-sockets and it is just 0.01 Amps. I don't think this small current requires separate switches, or do they? If you want to turn them off you turn them off with the same two buttons for the cabin lights (starboard and port) on the switchboard at the chart table.
What would you guys do?
Konstantin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Konstantin Quote  Post ReplyReply Direct Link To This Post Posted: 04 December 2016 at 19:41
I wouldn't bother with switches. I've got 2 USB chargers on Wurst panel and they are always on. But thank you for sharing! I will certainly do this next time I'm on the boat.
Fendant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fendant Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2016 at 00:10
Same here, I have installed two additional double USB sockets without switches.
robh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robh Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2016 at 00:38
The USB sockets you've installed in the Cabin light feed are fuse protected from the cabin light switch/fuse on the main panel but the one I have installed in my cabin is run directly back to the 12 volt switch/supply as is the one I have installed in the cockpit. These separate supplies require protection so connecting to the dedicated switch/fuse on the panel that Hanse installed when your boat was built provides that protection and keeps all your supplies in one place and on a fuse you can reset.
I certainly would not run in an additional separate electrical feed without installing circuit some form of protection, either a panel fuse or a separate inline one. This is more important with the 12volt connection in the cockpit as you never know what you or one of your crew may connect to this that may overload the circuit. This is the safest option ensuring that should you get a fault the fuse will blow rather than overheat the wiring with the possibility of setting your boat on fire.
As I have said by installing the low voltage/current USB sockets in the cabin light feed that was already installed by Hanse at the factory you have effected a fused USB connection at whatever rate the lights are fused, so these are protected.
Fusing other circuits is obviously your choice but don't you think your boat and your life is worth a little extra effort?
Stay safe.
Rob
This page was generated in 0.086 seconds.
